[mapguide-trac] #1957: Maestro 4 , ODBC connection: Timeout while saving
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 20 04:43:06 EST 2012
   Reporter:  janvw    |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 Connecting to big SQL Server 2000 databases (> 350 tables) via ODBC is
 causing Maestro to time-out while saving (see attached error message).
 The SQL server feature sources can be accessed successfully via FDO
 Toolbox and also the ODBC provider of AutoCAD Map 2008.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1957>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
