[mapguide-trac] #1924: Maestro - Base Map Scale Ranges
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jan 19 07:26:22 EST 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-4.1
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 A couple of minor edits to scale ranges to catch unexpected behaviour:
  1) When using the "Generate" button and the 'Exponential' method the
 scale ranges start at the 'Min Scale' but do not end at the 'Max Scale' -
 if I set a max I expect that to be preserved.  I think the "Number of
 Scales" is generating but missing the top end max scale which is not added
 in again as it would make numscales +1
  2) When manually editing a 'Display Scale' list and saving the list the
 Map is not invalidated (*) so it is easy to close and loose changes
  3) It maybe just me but unless I run full-screen I cannot see the
 'Generate' button, the scaling/position of the controls seems not to
 update if you shrink a window
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1924>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
