[mapguide-trac] #1930: Update build.bat to support VC10 compilation
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jan 26 21:24:09 EST 2012
   Reporter:  jng           |       Owner:
       Type:  task          |      Status:  new
   Priority:  low           |   Milestone:
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 Currently build.bat correctly uses the VC10 compiler if env vars are
 properly set up, but it still instructs msbuild to build the VS2008
 solution files.
 The batch files need to be updated to support compilation against the
 VS2010 solution files
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1930>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
