[Mapguide-trac] [mapguide-trac] #2053: WMS GETFEATUREINFO does not work with Gaia
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 3 05:12:48 PDT 2012
   Reporter:  jng            |       Owner:
       Type:  defect         |      Status:  new
   Priority:  low            |   Milestone:
  Component:  WMS Interface  |     Version:  2.4.0
   Severity:  trivial        |    Keywords:
External_id:                 |
 If you use Gaia to do a WMS GETFEATUREINFO for any layer served via WMS,
 it will return back the following response:
 <?xml version="1.0" encoding="UTF-8" ?>
 <ServiceExceptionReport version="1.3.0"
    xmlns="http://www.opengis.net/ogc"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:schemaLocation="http://www.opengis.net/ogc
 http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
  <ServiceException code="MissingInfoFormat">
   The request must contain an INFO_FORMAT parameter to specify the format
 of feature information (MIME type).
  </ServiceException>
 </ServiceExceptionReport>
 This is because the GetFeatureInfo requests sent from Gaia does not
 contain the INFO_FORMAT parameter.
 If we take Gaia's word for it (being a correct WMS client), this would
 imply that if an INFO_FORMAT parameter is not specified in the
 GetFeatureInfo request, then a default value should be provided (text/xml
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2053>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
