[Mapguide-trac] [mapguide-trac] #649: FeatureService.UpdateFeatures doesn't log errors and reports them as succesful
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 4 05:21:47 PDT 2012
succesful
 Reporter:  zspitzer         |         Owner:
     Type:  defect           |        Status:  closed
 Priority:  high             |     Milestone:  2.4
Component:  Feature Service  |       Version:  2.2.0
 Severity:  critical         |    Resolution:  fixed
 Keywords:                   |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed in 2.4 (r6846) and trunk (r6847)
 Please note that the behaviour is still the same (ie. If
 MgPropertyCollection contains MgStringProperty instances, it means that
 particular command had an exception thrown).
 The above changeset now properly logs such failures and documents this
 method behaviour in the API documentation.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/649#comment:10>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
