[Mapguide-trac] [mapguide-trac] #1989: Alias using UNC with spaces fails - Not listed under EnumerateUnmanagedData
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 6 10:11:24 PDT 2012
 Reporter:  andrewd  |         Owner:
     Type:  defect   |        Status:  closed
 Priority:  medium   |     Milestone:  2.4
Component:  General  |       Version:  2.1.0
 Severity:  major    |    Resolution:  worksforme
 Keywords:           |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 If an alias fails to be displayed under the XML result of
 EnumerateUnmanagedData it is because the MapGuide Server could not stat
 the given directory.
 I tried EnumerateUnmanagedData with a UNC containing spaces for mg-desktop
 (which has 100% identical logic to the MapGuide Server) and it could pick
 up the UNC in question.
 As a result, I would chalk this up to a permission related issue relating
 to the user account that the MapGuide Server process runs under.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1989#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
