[Mapguide-trac] [mapguide-trac] #2061: 2.4 branch tidy up
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 6 10:43:19 PDT 2012
   Reporter:  jng      |       Owner:
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  2.4
  Component:  General  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> We are currently using trunk fusion and CS-Map for the 2.4 branch. We
> need to start locking down the versions of these respective external
> dependencies:
>  * CS-Map: {{{/metacrs/csmap/branches/13.10/CsMapDev}}} (same as 2.4j)
>  * Fusion: TBD
> Also the installer components should also be branched to 2.4
New description:
 We are currently using trunk fusion and CS-Map for the 2.4 branch. We need
 dependencies:
  * CS-Map: {{{/metacrs/csmap/branches/13.10/CsMapDev}}} (same as adsk 2.4j
 branch)
  * Fusion: TBD
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2061#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
