[Mapguide-trac] [mapguide-trac] #2073: mg-desktop: Tiled Map support
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 13 01:31:25 PDT 2012
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  high         |   Milestone:
  Component:  Desktop API  |     Version:
   Severity:  major        |    Keywords:
External_id:               |
 The final holy grail to complete mg-desktop is tiled map support. The
 [http://brutile.codeplex.com BruTile] library takes out a lot of grunt
 work in calculating the tile planes and the required tiles to fetch. By
 adding a custom provider to support the Base Layer Groups in a Map
 Definition, we should be able to let BruTile figure out what tiles need to
 be fetched and rendered.
 By integrating BruTile, we also get Google/Bing/OSM layer support as well.
 But for this to work we'll impose the same restriction as Fusion does: The
 Map Definition has to be in WGS84.PseudoMercator
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2073>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
