[Mapguide-trac] [mapguide-trac] #2077: Maestro - Current Tab Setting
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 20 03:37:19 PDT 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  enhancement   |      Status:  new
   Priority:  low           |   Milestone:  Maestro-5.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 The Maestro tabs show the resource name (with tooltip)
 When you have two resources with the same name it is not immediately
 obvious which is which.
 This is OK apart from the issue that when a tab is already open, double-
 clicking on the resource tree does not set focus.
 Hence it is easy to have one tab with focus, double-click on an resource
 that is already open and not realise you have not changed tab.
 Long explanation but simply please ensure that even if a resource is open
 in a tab, set it's focus and make current on tree selection.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2077>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
