[Mapguide-trac] [mapguide-trac] #2080: MapGuide AJAX Properties Selection UI
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 20 11:10:14 PDT 2012
   Reporter:  crispinatime  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.4
  Component:  AJAX Viewer   |     Version:  2.4.0
   Severity:  minor         |    Keywords:
External_id:                |
 The properties UI in the AJAX viewer has some quirks and could provider a
 better experience.
 1) When the WebLayout is first loaded, if the width is less than about
 20px then the properties are not displayed for selected objects, even when
 the width of the properties panel is expanded.
 Observed in IE9.
 2) When the properties panel has been above about 20px in width and then
 contracted or minimised the object selection causes the drop-down feature
 type and count interfaces to appear floating on the map
 Observed in IE9 and Chrome 20.
 MapGuide 2.4 RC on .NET AjaxViewer
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2080>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
