[Mapguide-trac] [mapguide-trac] #2086: Maestro API - RuntimeMap DataExtent is Not Dynamic
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 27 05:34:05 PDT 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-5.0
  Component:  Maestro       |     Version:
   Severity:  major         |    Keywords:
External_id:                |
 In trying to get the actual current MapGuide viewable window extent the
 properties of the RuntimeMap appear to be static and not what is expected.
 See brief discussion:
 http://osgeo-org.1560.n6.nabble.com/Current-Map-DataExtent-via-Server-API-
 tt4990992.html
 To replicate:
 From the Maestro Source SVN launch the \SDK\SamplesWeb project
 If required, update to .NET 4 and add the 2.4 WebLayout manager to
 global.asax
 Add a breakpoint at line 52 of ToggleLayerVisibility.aspx.cs
 Run the project in debug mode and click on "Toggle Layer"
 When the breakpoint is hit the properties of the RuntimeMap object (rtMap)
 can be inspected - note the DataExtent, continue
 Zoom and pan the map - repeat click on "Toggle Layer" and observe values
 at breakpoint
 Expected Result - property of the runtime map reflects current map view
 extents
 Actual result - value of DataExtent is same as MapExtent and does not
 change
 If this is replicated I think the impact is high as it is not possible to
 determine what the user is viewing without an ugly client-side JavaScript
 parameter exchange
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2086>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
