[mapguide-trac] #1964: Group property empty on RuntimeMap layers from basemap group/layer
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 6 09:31:48 EST 2012
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  minor    |    Keywords:  MaestroAPI, base layer group
External_id:           |
 Steps to reproduce:
 1. Create a map with a group and a layer. Convert the group to a base
 layer group.
 When you create a runtimemap using IMappingService.CreateMap() and run the
 following code, the Group property string of the layer is empty:
   foreach (RuntimeMapLayer l in map.Layers)
     Console.Writeline(l.Group);
 Fix:
 in the MaestroAPI. RuntimeMap.cs constructor:
         internal RuntimeMap(IMapDefinition mdf, double metersPerUnit)
             : this(mdf.CurrentConnection)
 update the code inside:
  if(mdf.BaseMap != null)
                         foreach (var layer in group.BaseMapLayer)
                             var rtl = _mapSvc.CreateMapLayer(this, layer);
                             rtl.Visible = true;
                             rtl.Type = RuntimeMapLayer.kBaseMap;
 NEW LINE -->                rtl.Group = group.Name;
                             this.Layers.Add(rtl);
 Best regards
   Hans Milling...
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1964>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
