[mapguide-trac] #1957: Maestro 4 , ODBC connection: Timeout while saving
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 14 12:25:11 EDT 2012
   Reporter:  janvw    |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by jng):
 Ok, basically anywhere where it does a full schema walk is going to be
 trouble for your 350 table database. And the Layer Definition editor is
 one such area (it does the full schema walk to populate the list of
 available feature classes)
 I'll review the code base to see where such full schema walks are being
 done and to see  if that is truly necessary.
 But also keep an eye out for #2002. As this will let you reduce the attack
 surface of your database by building a slimmer configuration document,
 cutting down the number of tables/views that can be accessible to
 MapGuide.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1957#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
