[mapguide-trac] #1138: PATCH: Several fixes for fusion/layers/MapGuide/MapGuideViewerApi.js
MapGuide Open Source trac_mapguide at osgeo.org
Tue May 15 10:57:56 EDT 2012
 Reporter:  poulet1212  |         Owner:
     Type:  defect      |        Status:  closed
 Priority:  low         |     Milestone:
Component:  Fusion      |       Version:  2.0.2
 Severity:  minor       |    Resolution:  fixed
 Keywords:              |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Please check if the current stable release of Fusion, or the one bundled
 with the 2.4 preview resolves this issue. If not, please make a ticket on
 the Fusion trac instance.
 FYI, I noticed your patches were to simply get working Markup
 functionality. The release of Fusion bundled with 2.4 also has a Redline
 widget derived from the same original Generic Tasks example, which
 basically already solves what you are trying to achieve.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1138#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
