[Mapguide-trac] [mapguide-trac] #2134: Cannot delete resource with different schema version
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 6 23:15:36 PST 2012
 Reporter:  gBecker  |         Owner:  jng
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:  Maestro-5.0
Component:  Maestro  |       Version:  2.4.0
 Severity:  minor    |    Resolution:  wontfix
 Keywords:           |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 The problem is most likely due to a tainted repository from an older
 version that was just dropped into the new install instead of going
 through the proper repository update procedure.
 Either way, this is not Maestro's problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2134#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
