[Mapguide-trac] [mapguide-trac] #2179: Create standard folder structure
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 16 03:54:26 PST 2012
   Reporter:  osjonathan  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:  Maestro-5.0
  Component:  Maestro     |     Version:  2.1.0
   Severity:  critical    |    Keywords:
External_id:              |
 I am connected "locally" to my MapGuide 2.4.0.
 I right click on site in the explorer and click "Create Standard Folder
 Structure".
 I instantly get this error:
 System.NullReferenceException: Object reference not set to an instance of
 an object.
    at Maestro.Base.UI.SiteExplorer.get_ConnectionName() in c:\Program
 Files (x86)\Jenkins\jobs\Maestro
 trunk\workspace\Maestro.Base\UI\SiteExplorer.cs:line 113
    at Maestro.Base.UI.SiteExplorer.trvResources_SelectionChanged(Object
 sender, EventArgs e) in c:\Program Files (x86)\Jenkins\jobs\Maestro
 trunk\workspace\Maestro.Base\UI\SiteExplorer.cs:line 88
    at Aga.Controls.Tree.TreeViewAdv.OnSelectionChanged() in c:\Program
 trunk\workspace\Thirdparty\TreeViewAdv\Aga.Controls\Tree\TreeViewAdv.cs:line
 105
    at Aga.Controls.Tree.TreeViewAdv.EndUpdate() in c:\Program Files
 355
    at Aga.Controls.Tree.TreeViewAdv.set_SelectedNode(TreeNodeAdv value) in
 trunk\workspace\Thirdparty\TreeViewAdv\Aga.Controls\Tree\TreeViewAdv.Properties.cs:line
 689
    at Maestro.Base.UI.SiteExplorer.RefreshModel(String connectionName,
 String resId) in c:\Program Files (x86)\Jenkins\jobs\Maestro
 trunk\workspace\Maestro.Base\UI\SiteExplorer.cs:line 193
    at Maestro.Base.Commands.SiteExplorer.SetupFolderStructureCommand.Run()
 trunk\workspace\Maestro.Base\Commands\SiteExplorer\SetupFolderStructureCommand.cs:line
 62
    at ICSharpCode.Core.WinForms.MenuCommand.OnClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
 ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
 button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2179>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
