[Mapguide-trac] [mapguide-trac] #2184: Error: Invalid argument(s): The value cannot be less than or equal to zero.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 22 00:56:09 PST 2012
to zero.
 Reporter:  cmy                |         Owner:
     Type:  defect             |        Status:  reopened
 Priority:  high               |     Milestone:
Component:  Rendering Service  |       Version:  2.0.0
 Severity:  trivial            |    Resolution:
 Keywords:                     |   External_id:
Comment(by cmy):
 I want to know when it will cause this exception?
 I want to know how to do this will cause this exception?
 Now mapguie error logs often, leading to a dead map service.
 root/tags/MAPGUIDE2.0.2/Server/src/Services/Rendering/ServerRenderingService.cpp
 257         int width            = map->GetDisplayWidth();
 258         int height           = map->GetDisplayHeight();
 259         int dpi              = map->GetDisplayDpi();
 260         double scale         = map->GetViewScale();
 261         double metersPerUnit = map->GetMetersPerUnit();
 262         if (width <= 0 || height <= 0 || dpi <= 0 || scale <= 0.0 ||
 metersPerUnit <= 0.0)
 263             throw new
 MgInvalidArgumentException(L"MgServerRenderingService.RenderDynamicOverlay",
 __LINE__, __WFILE__, NULL, L"MgValueCannotBeLessThanOrEqualToZero", NULL);
 264
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2184#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
