[Mapguide-trac] [mapguide-trac] #2191: Maestro - ODBC Configuration Reset is Not Saved
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 29 03:00:57 PST 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-5.0
  Component:  Maestro       |     Version:
   Severity:  major         |    Keywords:
External_id:                |
Comment(by crispinatime):
 Close!  When I now try and manually edit/save the config document from the
 built-in editor I get the BOM problem "There is no Unicode byte order
 mark. Cannot switch to unicode" message coming up.
 Is there a different way required to set the configuration content from
 the XML?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2191#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
