[Mapguide-trac] [mapguide-trac] #2142: Extent in layer preview is calculated wrongly (OGR provider)
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 15 20:42:53 PDT 2012
   Reporter:  nkjoller  |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:  Maestro-5.0
  Component:  Maestro   |     Version:
   Severity:  minor     |    Keywords:
External_id:            |
Comment(by jng):
 Another thing to consider is to run ogrinfo against this data source. Does
 it return the same numbers for the bounding box? If so, then that
 particular OGR driver is the source of the problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2142#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
