[Mapguide-trac] [mapguide-trac] #2138: Maestro 5.0 SDK preparations
MapGuide Open Source trac_mapguide at osgeo.org
Sun Oct 28 20:38:57 PDT 2012
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> * ~~Review the existing SDK code samples and update/fix as required~~
>  * ~~Add an example using the new MapViewer component. Probably mirror
> the mg-desktop examples.~~
>  * Add an example demonstrating the add-in infrastructure
>  * ~~Add a LocalNative provider "template" project~~
>  * Review and cleanup API documentation
>  * Document the add-in infrastructure and include with published API
> documentation.
New description:
  * ~~Add an example using the new MapViewer component. Probably mirror the
  * ~~Add an example demonstrating the add-in infrastructure~~
 documentation.
  * Create NuGet packages for the MaestroAPI
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2138#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
