[Mapguide-trac] [mapguide-trac] #2254: Select Radius/Polygon
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 3 03:24:30 PDT 2013
   Reporter:  juanita  |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  2.5
  Component:  Fusion   |     Version:
   Severity:  minor    |    Keywords:
External_id:           |
 If You start Select Radius function and  than start Measure (of course
 doing Clear Selection after selection) the Select Radius function is not
 closed (similar like Measure function before Start and Stop button wasn’t
 available). We can see small radius circle of selection on every Measure
 vertex. Please see the attached movie.
 https://www.dropbox.com/s/wqrf2i47p2cgvq9/clip2.zip
 Similar situation is happens using Select Polygon. When You Clear
 Selection, selection is still active. Selection function cannot be closed
 by Esc either. So when You want to do measurement after selection You have
 two function in one: Selection and Measurement . Of course Measurements
 can be stopped by Stop button or Esc.
 https://www.dropbox.com/s/8y3isuq9pzsubpm/clip3.zip
 (MG 2.5 RC2 Apache without any changes, Windows 7, Server 2k8r2)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2254>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
