[Mapguide-trac] [mapguide-trac] #2255: setselection.aspx crashing IIS 7.5 application pool every few minutes
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 3 05:06:57 PDT 2013
   Reporter:  sreckol      |       Owner:
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:  setselection.aspx
External_id:               |
 I got this error on IIS 7.5 every few minutes:
 Exception: System.Runtime.Serialization.SerializationException
 Message: Type 'OSGeo.MapGuide.MgUnclassifiedException' in Assembly
 'OSGeo.MapGuide.Foundation, Version=1.0.0.1, Culture=neutral,
 PublicKeyToken=null' is not marked as serializable.
 StackTrace:    at
 System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitSerialize(Object
 obj, ISurrogateSelector surrogateSelector, StreamingContext context,
 SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter,
 ObjectWriter objectWriter)
    at
 System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.Serialize(Object
    at
 System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Serialize(Object
 graph, Header[] inHeaders, __BinaryWriter serWriter, Boolean fCheck)
    at
 System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(Stream
 serializationStream, Object graph, Header[] headers, Boolean fCheck)
    at
 System.Runtime.Remoting.Channels.CrossAppDomainSerializer.SerializeObject(Object
 obj, MemoryStream stm)
    at System.AppDomain.Serialize(Object o)
    at System.AppDomain.MarshalObject(Object o)
 I think that there should be also:
 '''features.Dispose();'''
 After adding this line error went out.
 Don't know if this should be also in setselection.jsp and setselection.php
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2255>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
