[Mapguide-trac] [mapguide-trac] #2265: Maestro copy contents of folder instead of the folder
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 29 01:00:41 PDT 2013
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Using Maestro 4.0.4, if I right click and copy a folder and past it
 somewhere else, the folder is not copied but the contents of the folder
 is.
 e.g.
 I have folders:
 test
  +featuresources
  +layers
  +maps
 test2
 I right click the test folder, choose copy and right click test2 and click
 paste. I would then expect the folder tree under test2 to look like this:
 test2
  +test
   +featuresources
   +layers
   +maps
 But instead the tree looks like this:
 test2
  +featuresources
  +layers
  +maps
 Best regards
   Hans Milling...
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2265>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
