[Mapguide-trac] [mapguide-trac] #2156: Ajax viewer X, Y coordinate precision are hard coded to 6 decimals
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 2 05:30:30 PDT 2013
#2156: Ajax viewer X,Y coordinate precision are hard coded to 6 decimals
 Reporter:  poulet1212                         |         Owner:
     Type:  enhancement                        |        Status:  closed
 Priority:  low                                |     Milestone:  2.6
Component:  AJAX Viewer                        |       Version:  2.1.0
 Severity:  trivial                            |    Resolution:  fixed
 Keywords:  mouse position decimal hard coded  |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 r7189 means you can just edit the cursorPosDecimalPlaces variable in
 mainframe.templ
 This is good enough of a fix.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2156#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
