[Mapguide-trac] [mapguide-trac] #2340: MgCooker using scaleindexes backwards while rendering tiles
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 29 04:26:07 PDT 2013
   Reporter:  Gyufi    |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  Maestro-5.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by 14364):
 Replying to [comment:5 jng]:
 > Is the issue basically when going through the "pyramid" of tiles to
 generate, MgCooker is starting from the bottom instead of the top?
 I don't understand exactly what you mean.
 If I understand you, then this is the answer:
   It doesn't matter where MgCooker starting the generation, bottom or top.
   With the above example
   With 1:90000 scale:
   - MgCooker using scaleindex=0
   - MapGuide using scaleindex=9
   With 1:250 scale:
   - MgCooker using scaleindex=9
   - MapGuide using scaleindex=0
   Another example:
     I generate tiles with MgCooker in 1:8000 scale (and only this scal),
 it generates tiles with scaleindex=4.
     MapGuide using scaleindex=5 for 1:8000 scale.
     Therefore when I view the Map in 1:4000 in Viewer (Fusion), it drawing
 1:8000 tiles to the left-top corner (of the entire map) and start to
 generate the remaining tiles in 1:4000 scale (which are not found in the
 TileCache). (I will attach a picture about it soon.)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2340#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
