[Mapguide-trac] [mapguide-trac] #2082: MapGuide 2.4 RC .NET IIS Install on Windows 8 / Windows Server 2012
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 12 04:45:56 PST 2013
   Reporter:  crispinatime  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.5
  Component:  Installer     |     Version:  2.4.0
   Severity:  major         |    Keywords:
External_id:                |
Comment(by crispinatime):
 I think this may be the solution: but I haven't got a full build
 environment set-up for MapGuide to test.
 Under : mapguide\Installer\Installers\MapGuide
 In : MapGuide.wxs
 Line : 535
 There is an explicit test for IIS v7 before the application pool dialog is
 displayed.
 <Publish Dialog="FastCgiWarningDlg" Control="Next" Event="NewDialog"
 Value="IIS7ConfigDlg" Order="4">MGWEB_CONFIG="IIS" AND
 IISVERSIONMAJOR="#7" AND (NOT NETFRAMEWORK40FULL)</Publish>
 Further searching for the string: IISVERSIONMAJOR="#7"
 shows there is a lot of dependency on IIS7
 I am not sure if a find/replace with the line below is OK but it's worth a
 go?
  (IISVERSIONMAJOR="#7" OR IISVERSIONMAJOR="#8")
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2082#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
