[Mapguide-trac] [mapguide-trac] #2217: Add Resampling Method for gdal feature source xml document
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 14 12:15:32 PST 2013
   Reporter:  steveg       |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  medium       |   Milestone:  Maestro-5.0
  Component:  Maestro      |     Version:
   Severity:  minor        |    Keywords:
External_id:               |
 I believe starting with FDO 3.8, resampling methods for gdal feature
 sources have been implemented.  Adding an option to select the resampling
 method to be added as a parameter in the feature source xml document would
 be helpful instead of having to manually input.  See:
 http://osgeo-org.1560.n6.nabble.com/RFC-65-Implement-Resampling-for-GDAL-
 Provider-tp5008350p5010166.html
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2217>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
