[Mapguide-trac] [mapguide-trac] #2224: First failed MgInitializeWebTier() call renders all future MgInitializeWebTier() calls to fail
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 26 05:22:45 PST 2013
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Web API  |     Version:  2.1.0
   Severity:  major    |    Keywords:
External_id:           |
 #2206 tries to improve the means to resolve the symptom.
 This ticket is the cause.
 A bad first call to MgInitializeWebTier() will render future calls to the
 same method to fail, generally with the message:
 Failed to load the resource file "Resources/mapguide_en.res" for locale
 "en"
 Something in that bad first call is being retained for subsequent calls,
 preventing a successful web tier initialization for that web server
 process. A web server restart or application pool recycle is then required
 in order to be able to attempt another successful MgInitializeWebTier()
 Attached is a php script demonstrating the problem. Must run php script
 from a cold start (and not a pre-existing php-cgi.exe process)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2224>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
