[Mapguide-trac] [mapguide-trac] #2191: Maestro - ODBC Configuration Reset is Not Saved
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 9 08:05:21 PDT 2013
 Reporter:  crispinatime  |         Owner:  jng
     Type:  defect        |        Status:  closed
 Priority:  medium        |     Milestone:  Maestro-5.0
Component:  Maestro       |       Version:
 Severity:  major         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I applied your suggested fix in r7683
 Regarding the error message
 There is no Unicode byte order mark. Cannot switch to unicode
 Check the XML prolog, it probably is saying utf-16 instead of utf-8. I
 currently don't know why this happens (why the XML is generated with
 utf-16), but changing utf-16 back to utf-8 fixes this error.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2191#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
