[Mapguide-trac] [mapguide-trac] #599: Set scale ranges by group?
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 19 00:34:36 PDT 2013
 Reporter:  andrewd      |         Owner:  jng
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:  Maestro-5.0
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:  wontfix
 Keywords:               |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Rather than me trying to solve this problem. Maestro's new embedded
 IronPython scripting engine lets you be able to solve this yourself.
 You basically want something similar to
 [http://trac.osgeo.org/mapguide/wiki/CodeSamples/Other/MaestroScripts/ScaleRangeUpdate
 this sample script]
 That currently works off of all Layer Definitions in a particular folder,
 but you can easily modify it to operate off of all layers in a Map
 Definition group instead.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/599#comment:12>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
