[Mapguide-trac] [mapguide-trac] #2322: Maestro 5 (Error: The type System.Double is not supported for primary keys)
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 25 00:04:47 PDT 2013
   Reporter:  lelik1973  |       Owner:  jng
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:  Maestro-5.0-maintenance
  Component:  Maestro    |     Version:  2.5.0
   Severity:  trivial    |    Keywords:
External_id:             |
 keys)[[BR]]
 I have a layer, stored in Oracle DB (FeatureSource KingOra,
 LayerDefinition-2.3.0)[[BR]]
 MapGuide 2.5 32bit[[BR]]
 If I try select object in preview window in Maestro 5.0.0, I see error
 window "The type System.Double is not supported for primary keys"[[BR]]
 If I try select object in preview browser window in Maestro 4.0.6, all is
 well.[[BR]]
 Primary key in this layer (table) is NUMBER (Prtecision 0)[[BR]]
 What could be wrong?[[BR]]
 Thank you![[BR]]
 Alexey[[BR]]
 lelik1973 at inbox.ru
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2322>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
