[Mapguide-trac] [mapguide-trac] #2328: Maestro: Consider adding an option to "open all dependent resources"
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 31 10:13:07 PDT 2013
   Reporter:  jasonbirch   |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 It would be great if I could click on a resource in the navigation tree
 and (either through the context menu, the References tab on the Properties
 window, or in the Compile Full Dependency List output window) open all or
 a subset of the identified dependent resources, or resources the resource
 is dependent on.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2328>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
