[Mapguide-trac] [mapguide-trac] #2295: Mapguide contains non-free code
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 20 02:52:51 PDT 2013
   Reporter:  johanvdw  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:  2.5.0
   Severity:  trivial   |    Keywords:
External_id:            |
 The current build system relies on GPC, which has a non-free/non-
 opensource license:
 https://svn.osgeo.org/mapguide/trunk/MgDev/Oem/agg-2.4/gpc/copying.txt
  This software is free '''for non-commercial use'''.
 The current makefile uses this library by default.
 https://svn.osgeo.org/mapguide/trunk/MgDev/Oem/agg-2.4/src/Makefile
  Agg contains an option to build without GPC. I think this should be the
 default option, otherwise our binaries can not be used for commercial use
 (whatever the definition may be).
 If fixing, consider supporting more recent versions of agg.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2295>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
