[Mapguide-trac] [mapguide-trac] #2299: Drag/Drop layers into Map Definition editor improperly handled
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jun 23 23:44:47 PDT 2013
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.5.0
   Severity:  trivial  |    Keywords:
External_id:           |
 If you drag and drop layers into a group of a Map Definition editor, if
 there are layers of the same name, for reasons currently unknown, they are
 also moved into this group.
 Consider this layer/group structure
  * Foo
    * Layer 1
    * Layer 2
    * Layer 3
  * Bar
 If you drag/drop in [Layer 1/Layer 2/Layer 3] into the "Bar" folder, the
 existing [Layer 1/Layer 2/Layer 3] are moved into this folder as well. The
 result currently looks like this:
  * Foo
  * Bar
    * Layer 1
    * Layer 2
    * Layer 3
    * Layer 10
    * Layer 20
    * Layer 30
 It should be like this:
  * Foo
    * Layer 1
    * Layer 2
    * Layer 3
  * Bar
    * Layer 10
    * Layer 20
    * Layer 30
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2299>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
