[Mapguide-trac] [mapguide-trac] #2300: XML Validation Error: SymbolDefinition-1.1.0.xsd
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 25 04:26:24 PDT 2013
 Reporter:  andymorf  |         Owner:  jng
     Type:  defect    |        Status:  closed
 Priority:  low       |     Milestone:  Maestro-5.1
Component:  Maestro   |       Version:  2.5.0
 Severity:  critical  |    Resolution:  fixed
 Keywords:            |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed trunk (r7639) and 4.0.x (r7640)
 To answer your question: We have strongly-typed classes generated from all
 the known xsds (up to 2.4) defined in the Maestro API assemblies, so the
 application code can work with classes and interfaces instead of raw XML
 documents.
 Thus Maestro will work even if the xsd files aren't physically present in
 the Maestro install. However XML validation via the generic XML editor
 will fail if the matching xsd file is not present. That's what those files
 are currently used for.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2300#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
