[Mapguide-trac] [mapguide-trac] #2299: Drag/Drop layers into Map Definition editor improperly handled
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 26 02:07:14 PDT 2013
 Reporter:  jng      |         Owner:  jng
     Type:  defect   |        Status:  reopened
 Priority:  low      |     Milestone:  Maestro-5.0
Component:  Maestro  |       Version:  2.5.0
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Changes (by jng):
  * status:  closed => reopened
  * resolution:  worksforme =>
Comment:
 I can reproduce this now.
 The problem is that if you have a group "Foo" and then you try to create
 another empty group "Foo1", the moment you type "Foo", all of the layers
 under "Foo" will then auto-associate themselves with whatever name you
 continue to type, thus ending up under the group "Foo1"
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2299#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
