[Mapguide-trac] [mapguide-trac] #2305: mg-desktop: Aliases not substituted in configuration documents
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 27 23:16:55 PDT 2013
   Reporter:  jng          |       Owner:  jng
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Desktop API  |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by jng:
Old description:
> If you specify any aliases in a Raster configuration document. mg-desktop
> is not properly applying substitution to actual physical paths, like its
> MapGuid Server counterpart.
New description:
 If you specify any aliases in a Raster configuration document, mg-desktop
 is not properly applying substitution to actual physical paths like its
 MapGuide Server counterpart.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2305#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
