[Mapguide-trac] [mapguide-trac] #2340: MgCooker using scaleindexes backwards while rendering tiles
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 6 03:24:00 PDT 2013
 Reporter:  Gyufi    |         Owner:  jng
     Type:  defect   |        Status:  closed
 Priority:  high     |     Milestone:  Maestro-5.0-maintenance
Component:  Maestro  |       Version:
 Severity:  major    |    Resolution:  wontfix
 Keywords:           |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Sorry I cannot accept this patch.
 I compared the tile directories that the AJAX Viewer and MgCooker (without
 this patch) produces. They are identical in directory structure and
 content.
 I then compared the AJAX viewer tile directory against the one produced by
 MgCooker with this patch. The directory structure is radically different,
 and the MgCooker one has way more blank tiles generated.
 I then noticed the version of Maestro you're using. '''5.0.0.7213''' is
 beta 5. Final release is '''5.0.0.7698'''. There have been many changes
 and fixes to MgCooker in the time between these releases.
 I'm certain your issue would be solved by just upgrading your beta 5
 installation of Maestro 5.0 to the final release.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2340#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
