[Mapguide-trac] [mapguide-trac] #2393: Make textsymbol more configurable
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 1 08:18:14 PDT 2014
   Reporter:  gabrimonfa   |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  General      |     Version:  2.5.0
   Severity:  trivial      |    Keywords:
External_id:               |
Comment(by gabrimonfa):
 No, I'm not aware of any built-in web tier application (btw which are the
 built-in web tier applications? Ajax viewer and Fusion viewer?) that would
 benefit from this change.
 I'm doing this change in my custom version of MapGuide (applying it in
 every new version) since I need to be able to stylize differently some
 textsymbols.
 So obviously I would need to apply one fewer patch if this change goes
 upstream.
 I filed this enhancement since I realized that a similar change was made
 for other templates (that I also use to change in every version, in order
 to have more style configurations).
 ''AreaRule.templ'' Mapguide 2.4
     <Stroke>
         <LineStyle>Solid</LineStyle>
         <Thickness>1</Thickness>
         <Color>FF000000</Color>
         <Unit>Points</Unit>
         <SizeContext>DeviceUnits</SizeContext>
     </Stroke>
 ''AreaRule.templ'' Mapguide 2.5.2
         <Stroke>
             <LineStyle>%s</LineStyle>
             <Thickness>%s</Thickness>
             <Color>%s</Color>
             <Unit>%s</Unit>
             <SizeContext>%s</SizeContext>
         </Stroke>
 Feel free to close this enhancement as non acceptable if the change is
 deemed non appropriate.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2393#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
