[Mapguide-trac] [mapguide-trac] #2271: New Resource Dialog: Add filter to show latest schema version only
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 10 07:43:05 PDT 2014
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-5.1
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Comment(by crispinatime):
 I was about to open a ticket but think it would have been duplication so
 will add some support to this.  The 'New Resource' dialog could do with a
 rethink.  Some things to consider:
 I still end up constantly updating resources because finding the latest
 for my server version is more time consuming.
  * As Maestro knows the current server version (if one connection open) it
 should offer the relevant schema versions.
  * Change the multi-select (left-hand list) to a large icon list - making
 it easy to pick a version.  Latest at the top and a default set (see
 above)
  * The Templates list is too complicated.  For a particular server version
 what I want to see is instead of categorised by templates, categorised by
 type and showing not the new templates for that version but the *latest*
 valid in all types for that version.
 For example if I am on MapGuide OS 2.2 I would see:
  - Feature Source
  - Vector Layer Definition (v1.3)
  - Web Layout (v1.1)
 (etc)
  * Possibly below this (hidden or collapsed by default) would be older
 (valid) versions of the templates accessible only if required.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2271#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
