[Mapguide-trac] [mapguide-trac] #1664: Selection of rasterfiles via MG_DATA_PATH_ALIAS in composite type
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 17 06:08:13 PDT 2014
 Reporter:  gBecker      |         Owner:  jng
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:  Maestro-3.0
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
Comment(by jng):
 Are you really sure MG server will do alias substitution on configuration
 documents?
 My findings have been that this is not the case as alias substitution is
 not set for resource data files (of which a configuration document is one
 of).
 I've made a ticket for this (#2433), but I'm not keen on fixing it for 2.6
 as AIMS 2015 probably has been released and I want to keep this current
 behavior for compatibility purposes.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1664#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
