[Mapguide-trac] [mapguide-trac] #2434: Remove SQL query support from HTTP connection provider
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 17 09:45:56 PDT 2014
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-6.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> SQL query execution has been removed from the mapagent (why this was in
> there in the first place is anyone's guess)
> As such, the SQL query support in the HTTP connection provider is not
> dead-weight and should be removed.
New description:
 SQL query execution has been removed from the mapagent (why this feature
 was in there in the first place is anyone's guess)
 As such, the SQL query support in the HTTP connection provider is now
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2434#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
