[Mapguide-trac] [mapguide-trac] #2403: Map previewing a layer will freeze Maestro when opening a resource
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 21 10:33:20 PDT 2014
 Reporter:  pcardinal             |         Owner:  jng
     Type:  defect                |        Status:  reopened
 Priority:  medium                |     Milestone:  Maestro-6.0
Component:  Maestro               |       Version:
 Severity:  major                 |    Resolution:
 Keywords:  preview layer freeze  |   External_id:
Changes (by pcardinal):
  * status:  closed => reopened
  * resolution:  invalid =>
Comment:
 You can use the data from Sheboygan to produce the defect
 The problem occurs only when the Mapguide server is not on the same
 machine running Maestro.
 In fact I have no problem with the following ressouce
 "http://localhost/mapguide2.5" but I have a problem with
 "http://houleag.com/mapguide" which is on a different machine then the one
 running Maestro.
 I did some tests with different machines running different OS (server 2012
 and Windows 7). The problem occurs with the Internet and with an intranet.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2403#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
