[Mapguide-trac] [mapguide-trac] #2400: MENTOR_DICTIONARY_PATH var env problem with MAP3D
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 4 22:55:48 PST 2014
   Reporter:  poulet1212  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Installer   |     Version:  2.5.0
   Severity:  trivial     |    Keywords:  MENTOR_DICTIONARY_PATH, map3d
External_id:              |
Comment(by jng):
 MapGuide hasn't used MENTOR_DICTIONARY_PATH since 2.4 as a result of RFC
 122 (http://trac.osgeo.org/mapguide/wiki/MapGuideRfc122)
 If a MENTOR_DICTIONARY_PATH env var exists, it will be used by MGOS only
 if the configured MentorDictionaryPath in serverconfig.ini/webconfig.ini
 does not exist. If the MentorDictionaryPath setting is valid, the
 MENTOR_DICTIONARY_PATH is not required for MGOS to operate.
 I'll check the installer to see if it is still creating
 MENTOR_DICTIONARY_PATH. If it does, we'll remove that part from the
 installer as it is no longer required.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2400#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
