[Mapguide-trac] [mapguide-trac] #2401: MgUnclassifiedException on every tile request
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 10 05:43:02 PST 2014
   Reporter:  Gyufi         |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.6
  Component:  Tile Service  |     Version:  2.5.0
   Severity:  blocker       |    Keywords:
External_id:                |
 Using MapGuide OSGeo 2.5, Fusion Viewer with Tile Based Map.
 MapGuide does'nt able to respond any tile images, Map div is fully pink.
 mgserver.exe process using ~260 MB memory.
 Error message:
 "Problem:
 The application encountered a problem and could not finish the operation
 you just requested properly.
 Solution:
 If it's the first time you met this problem, try again or restart the
 application / session; otherwise, describe the steps to reproduce this
 problem to the server administrator for suggestions. -
 IsapiAgent.HttpExtensionProc() line 211 file IsapiAgent.cpp -
 MgConfiguration.GetBoolValue() line 250 file
 c:\mg-2.5-x64\mgdev\common\foundation\System/Configuration.cpp -
 MgConfiguration.GetValue() line 375 file
 c:\mg-2.5-x64\mgdev\common\foundation\System/Configuration.cpp"
 We think, the exception occurs in IsapiAgent.cpp line 171
 (MapAgentCommon::LogRequest).
 Temporary solution: In IIS set recycling to Application Pool.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2401>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
