[Mapguide-trac] [mapguide-trac] #2466: Fix bad ids in VotingDistricts data source
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 10 01:08:30 PDT 2014
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  2.6
  Component:  Samples  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 The VotingDistricts data source after the Sheboygan dataset revamp, has
 feature ids starting from 0.
 This makes it unintuitive for some sample code where to select parcels by
 owner under district 1 requires passing in FeatId = 0
 We should fix the ids on this data store.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2466>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
