[Mapguide-trac] [mapguide-trac] #2468: Random MSB3073 errors building WebTier from scratch
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 10 19:08:04 PDT 2014
   Reporter:  jng           |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.6
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 On random occasions I've encountered various MSB3073 pre/post build
 failures when building the WebTier solution.
 Build log analysis reveals that the *Api projects can fail on the SWIG
 generation step as some upstream SWIG interface files have not been
 generated yet.
 That means for all this time, whenever we did have a successful build, it
 was due to the grace of the gods of OS/MSBuild scheduling that ensured the
 relevant upstream projects were built before it went through building *Api
 projects.
 The cause is that the dependencies between the *Api projects have not been
 specified in the solution file. The fix is to explicitly specify these
 dependencies.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2468>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
