[Mapguide-trac] [mapguide-trac] #2503: WebLayout missing MapTip tool when upgrading
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 19 07:35:52 PST 2014
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.5.0
   Severity:  minor    |    Keywords:
External_id:           |
 If you take an old WebLayout (pre-2.6 - in my case v2.2) that's on a 2.6
 server and open it in Maestro, it's missing the MapTip tool and also the
 ability to add it (it's not listed as a "built-in command"). I think that
 the result of this is that old WebLayouts won't show tooltips correctly.
 In my case, if I created a new WebLayout with the same map as the old
 layout, the tooltips worked fine (and the maptip command is available).
 I'm attaching the XML for the WebLayout in question - this is the upgraded
 version, but is missing the MapTip command and has a problem showing
 tooltips (possibly as a result of that).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2503>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
