[Mapguide-trac] [mapguide-trac] #2507: Error after adding second map to Fusion
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 20 10:08:32 PST 2014
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.5.0
   Severity:  trivial  |    Keywords:
External_id:           |
 Create a Fusion application, then go to "Maps" and add a 2nd map under
 "Currently Available Maps". The map gets added correctly, but you can't
 select it. As soon as you select it, you get an error - which means that
 you can't configure it, or even delete it.
 Error is:
 System.NullReferenceException: Object reference not set to an instance of
 an object.
    at Maestro.Editors.Fusion.MapCtrl..ctor(IApplicationDefinition appDef,
 IMapGroup group, IEditorService edService, IMapWidget widget) in
 c:\working\JenkinsCI\home\slave_win\jobs\Maestro
 trunk\workspace\Maestro.Editors\Fusion\MapCtrl.cs:line 105
    at
 Maestro.Editors.Fusion.MapSettingsCtrl.lstMaps_SelectedIndexChanged(Object
 sender, EventArgs e) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
 trunk\workspace\Maestro.Editors\Fusion\MapSettingsCtrl.cs:line 119
    at System.Windows.Forms.ListView.OnSelectedIndexChanged(EventArgs e)
    at System.Windows.Forms.ListView.WmReflectNotify(Message& m)
    at System.Windows.Forms.ListView.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2507>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
