[Mapguide-trac] [mapguide-trac] #2509: Overview Map offset with External Providers
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 21 10:34:18 PST 2014
   Reporter:  andrewd   |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  Fusion    |     Version:  2.5.0
   Severity:  critical  |    Keywords:
External_id:            |
 The box showing the current location in the Overview Map widget gets
 offset (incorrectly) when you have External Providers enabled. If you turn
 off the commercial layers, the map works fine and the box is where it
 should be. The second you enable the external providers, the box jumps to
 a new (wrong) spot.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2509>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
